Constant Field Values
Contents
org.eclipse.*
org.eclipse.ant.core.AntCorePlugin
public static final String ANT_BUILDFILE_CONTENT_TYPE "org.eclipse.ant.core.antBuildFile"
public static final String CLASS "class"
public static final String ECLIPSE_PROGRESS_MONITOR "eclipse.progress.monitor"
public static final String ECLIPSE_RUNTIME "eclipseRuntime"
public static final int ERROR_LIBRARY_NOT_SPECIFIED 3
public static final int ERROR_MALFORMED_URL 2
public static final int ERROR_RUNNING_BUILD 1
public static final String HEADLESS "headless"
public static final int INTERNAL_ERROR 120
public static final String LIBRARY "library"
public static final String NAME "name"
public static final String PI_ANTCORE "org.eclipse.ant.core"
public static final String PT_EXTRA_CLASSPATH "extraClasspathEntries"
public static final String PT_PROPERTIES "antProperties"
public static final String PT_TASKS "antTasks"
public static final String PT_TYPES "antTypes"
public static final String VALUE "value"
org.eclipse.ant.internal.core.AbstractEclipseBuildLogger
public static final String ANT_PROCESS_ID "org.eclipse.ant.core.ANT_PROCESS_ID"
org.eclipse.ant.internal.core.IAntCoreConstants
public static final String DEFAULT_BUILD_FILENAME "build.xml"
public static final String PREFERENCE_ADDITIONAL_ENTRIES "additional_entries"
public static final String PREFERENCE_ANT_HOME "ant_home"
public static final String PREFERENCE_ANT_HOME_ENTRIES "ant_home_entries"
public static final String PREFERENCE_CLASSPATH_CHANGED "classpath_changed"
public static final String PREFERENCE_PROPERTIES "properties"
public static final String PREFERENCE_PROPERTY_FILES "propertyfiles"
public static final String PREFERENCE_TASKS "tasks"
public static final String PREFERENCE_TYPES "types"
public static final String PREFIX_PROPERTY "property."
public static final String PREFIX_TASK "task."
public static final String PREFIX_TYPE "type."
org.eclipse.ant.internal.ui.AntImageDescriptor
public static final int HAS_ERRORS 1
public static final int HAS_WARNINGS 4
public static final int IMPORTED 2
org.eclipse.ant.internal.ui.AntUIPlugin
public static final String PI_ANTUI "org.eclipse.ant.ui"
org.eclipse.ant.internal.ui.AntUtil
public static final char ANT_CLASSPATH_DELIMITER 42
public static final String ANT_GLOBAL_USER_CLASSPATH_PLACEHOLDER "UG"
public static final String ANT_HOME_CLASSPATH_PLACEHOLDER "G"
public static final String ATTRIBUTE_SEPARATOR ","
org.eclipse.ant.internal.ui.IAntUIConstants
public static final String ANT_VIEW_ID "org.eclipse.ant.ui.AntView"
public static final String ATTR_DEFAULT_VM_INSTALL "org.eclipse.ant.ui.DEFAULT_VM_INSTALL"
public static final String DIALOGSTORE_LASTANTHOME "org.eclipse.ant.ui.lastanthome"
public static final String DIALOGSTORE_LASTEXTFILE "org.eclipse.ant.ui.lastextfile"
public static final String DIALOGSTORE_LASTEXTJAR "org.eclipse.ant.ui.lastextjar"
public static final String DIALOGSTORE_LASTFOLDER "org.eclipse.ant.ui.lastfolder"
public static final String IMG_ADD "org.eclipse.ant.ui.add"
public static final String IMG_ANT "org.eclipse.ant.ui.ant"
public static final String IMG_ANT_BUILD_TAB "org.eclipse.ant.ui.IMG_BUILD_TAB"
public static final String IMG_ANT_DEFAULT_TARGET "org.eclipse.ant.ui.antDefaultTarget"
public static final String IMG_ANT_ECLIPSE_RUNTIME_OBJECT "org.eclipse.ant.ui.antEclipse"
public static final String IMG_ANT_IMPORT "org.eclipse.ant.ui.antImport"
public static final String IMG_ANT_MACRODEF "org.eclipse.ant.ui.antMacrodef"
public static final String IMG_ANT_PROJECT "org.eclipse.ant.ui.antProject"
public static final String IMG_ANT_TARGET "org.eclipse.ant.ui.antTarget"
public static final String IMG_ANT_TARGET_ERROR "org.eclipse.ant.ui.antTargetError"
public static final String IMG_ANT_TARGET_INTERNAL "org.eclipse.ant.ui.antPrivateTarget"
public static final String IMG_ANT_TASKDEF "org.eclipse.ant.ui.antTaskdef"
public static final String IMG_ANT_TYPE "org.eclipse.ant.ui.type"
public static final String IMG_FILTER_IMPORTED_ELEMENTS "org.eclipse.ant.ui.filterImportedElements"
public static final String IMG_FILTER_INTERNAL_TARGETS "org.eclipse.ant.ui.filterInternalTargets"
public static final String IMG_FILTER_PROPERTIES "org.eclipse.ant.ui.filterProperties"
public static final String IMG_FILTER_TOP_LEVEL "org.eclipse.ant.ui.filterTopLevel"
public static final String IMG_LINK_WITH_EDITOR "org.eclipse.ant.ui.linkWithEditor"
public static final String IMG_MARK_OCCURRENCES "org.eclipse.ant.ui.markOccurrences"
public static final String IMG_OVR_ERROR "org.eclipse.ant.ui.ovrError"
public static final String IMG_OVR_IMPORT "org.eclipse.ant.ui.ovrImport"
public static final String IMG_OVR_WARNING "org.eclipse.ant.ui.ovrWarning"
public static final String IMG_PROPERTY "org.eclipse.ant.ui.IMG_PROPERTY"
public static final String IMG_REFRESH "org.eclipse.ant.ui.IMG_REFRESH"
public static final String IMG_REMOVE "org.eclipse.ant.ui.remove"
public static final String IMG_REMOVE_ALL "org.eclipse.ant.ui.removeAll"
public static final String IMG_RUN "org.eclipse.ant.ui.run"
public static final String IMG_SEARCH "org.eclipse.ant.ui.search"
public static final String IMG_SEGMENT_EDIT "org.eclipse.ant.ui.segmentEdit"
public static final String IMG_SORT_OUTLINE "org.eclipse.ant.ui.sortOutline"
public static final String IMG_TAB_ANT_TARGETS "org.eclipse.ant.ui.IMG_TAB_ANT_TARGETS"
public static final String IMG_TAB_CLASSPATH "org.eclipse.ant.ui.IMG_TAB_CLASSPATH"
public static final String IMG_TAB_MAIN "org.eclipse.ant.ui.IMG_TAB_MAIN"
public static final String IMG_TASK_PROPOSAL "org.eclipse.ant.ui.html_tab_obj"
public static final String IMG_TEMPLATE_PROPOSAL "org.eclipse.ant.ui.template_obj"
public static final String IMG_WIZARD_BANNER "org.eclipse.ant.ui.IMG_WIZARD_BANNER"
public static final int LEFT_COLUMN_SIZE 15
public static final String PLUGIN_ID "org.eclipse.ant.ui"
public static final String REMOTE_ANT_PROCESS_FACTORY_ID "org.eclipse.ant.ui.remoteAntProcessFactory"
public static final String SET_INPUTHANDLER "org.eclipse.ant.uiSET_INPUTHANDLER"
public static final int STATUS_INIT_RUN_ANT 1000
org.eclipse.ant.internal.ui.IAntUIHelpContextIds
public static final String ADD_BUILDFILE_ACTION "org.eclipse.ant.ui.add_buildfile_action_context"
public static final String ADD_PROPERTY_DIALOG "org.eclipse.ant.ui.add_property_dialog_context"
public static final String ADD_TASK_DIALOG "org.eclipse.ant.ui.add_task_dialog_context"
public static final String ADD_TYPE_DIALOG "org.eclipse.ant.ui.add_type_dialog_context"
public static final String ANT_BUILD_TAB "org.eclipse.ant.ui.ant_build_tab_context"
public static final String ANT_CLASSPATH_PAGE "org.eclipse.ant.ui.ant_classpath_page_context"
public static final String ANT_CLASSPATH_TAB "org.eclipse.ant.ui.ant_classpath_tab_context"
public static final String ANT_EDITOR "org.eclipse.ant.ui.ant_editor_context"
public static final String ANT_EDITOR_PREFERENCE_PAGE "org.eclipse.ant.ui.ant_editor_preference_page_context"
public static final String ANT_JRE_PAGE "org.eclipse.ant.ui.ant_jre_page_context"
public static final String ANT_JRE_TAB "ant_jre_tab_context"
public static final String ANT_MAIN_TAB "org.eclipse.ant.ui.ant_main_tab_context"
public static final String ANT_PREFERENCE_PAGE "org.eclipse.ant.ui.ant_preference_page_context"
public static final String ANT_PROPERTIES_PAGE "org.eclipse.ant.ui.ant_properties_page_context"
public static final String ANT_PROPERTIES_TAB "org.eclipse.ant.ui.ant_properties_tab_context"
public static final String ANT_RUNTIME_PREFERENCE_PAGE "org.eclipse.ant.ui.ant_runtime_preference_page_context"
public static final String ANT_TARGETS_TAB "org.eclipse.ant.ui.ant_targets_tab_context"
public static final String ANT_TASKS_PAGE "org.eclipse.ant.ui.ant_tasks_page_context"
public static final String ANT_TYPES_PAGE "org.eclipse.ant.ui.ant_types_page_context"
public static final String ANT_VIEW "org.eclipse.ant.ui.ant_view_context"
public static final String EDIT_LAUNCH_CONFIGURATION_ACTION "org.eclipse.ant.ui.edit_launch_configuration_action_context"
public static final String EDIT_PROPERTY_DIALOG "org.eclipse.ant.ui.edit_property_dialog_context"
public static final String EDIT_TASK_DIALOG "org.eclipse.ant.ui.edit_task_dialog_context"
public static final String EDIT_TYPE_DIALOG "org.eclipse.ant.ui.edit_type_dialog_context"
public static final String MESSAGE_WITH_TOGGLE_DIALOG "org.eclipse.ant.ui.message_with_toggle_dialog_context"
public static final String PREFIX "org.eclipse.ant.ui."
public static final String REFRESH_BUILDFILE_ACTION "org.eclipse.ant.ui.refresh_buildfile_action_context"
public static final String REMOVE_ALL_ACTION "org.eclipse.ant.ui.remove_all_action_context"
public static final String REMOVE_PROJECT_ACTION "org.eclipse.ant.ui.remove_project_action_context"
public static final String RUN_TARGET_ACTION "org.eclipse.ant.ui.run_target_action_context"
public static final String SEARCH_FOR_BUILDFILES_ACTION "org.eclipse.ant.ui.search_for_buildfiles_action_context"
public static final String SEARCH_FOR_BUILDFILES_DIALOG "org.eclipse.ant.ui.search_for_buildfiles_dialog_context"
public static final String STATUS_DIALOG "org.eclipse.ant.ui.status_dialog_context"
public static final String TARGET_MOVE_DOWN_ACTION "org.eclipse.ant.ui.target_move_down_action_context"
public static final String TARGET_MOVE_UP_ACTION "org.eclipse.ant.ui.target_move_up_action_context"
public static final String TARGET_ORDER_DIALOG "org.eclipse.ant.ui.target_order_dialog_context"
org.eclipse.ant.internal.ui.IAntUIPreferenceConstants
public static final String ANT_ERROR_DIALOG "errorDialog"
public static final String ANT_FIND_BUILD_FILE_NAMES "ant.findBuildFileNames"
public static final String ANT_TOOLS_JAR_WARNING "toolsJAR"
public static final String ANTEDITOR_FILTER_IMPORTED_ELEMENTS "anteditor.filterImportedElements"
public static final String ANTEDITOR_FILTER_INTERNAL_TARGETS "anteditor.filterInternalTargets"
public static final String ANTEDITOR_FILTER_PROPERTIES "anteditor.filterProperties"
public static final String ANTEDITOR_FILTER_TOP_LEVEL "anteditor.filterTopLevel"
public static final String ANTEDITOR_SORT "anteditor.sort"
public static final String ANTVIEW_INCLUDE_ERROR_SEARCH_RESULTS "antview.includeErrorSearchResults"
public static final String ANTVIEW_LAST_SEARCH_STRING "antview.lastSearchString"
public static final String ANTVIEW_LAST_WORKINGSET_SEARCH_SCOPE "antview.lastSearchScope"
public static final String ANTVIEW_USE_WORKINGSET_SEARCH_SCOPE "antview.useWorkingSetSearchScope"
public static final String CONSOLE_DEBUG_COLOR "org.eclipse.ant.ui.debugColor"
public static final String CONSOLE_ERROR_COLOR "org.eclipse.ant.ui.errorColor"
public static final String CONSOLE_INFO_COLOR "org.eclipse.ant.ui.informationColor"
public static final String CONSOLE_VERBOSE_COLOR "org.eclipse.ant.ui.verboseColor"
public static final String CONSOLE_WARNING_COLOR "org.eclipse.ant.ui.warningColor"
public static final String DOCUMENTATION_URL "documentation.url"
public static final String OUTLINE_LINK_WITH_EDITOR "outline.linkWithEditor"
org.eclipse.ant.internal.ui.debug.IAntDebugConstants
public static final String ANT_RUN_TO_LINE "org.eclipse.ant.ui.runToLineBreakpoint"
public static final String ID_ANT_DEBUG_MODEL "org.eclipse.ant.ui.debug"
public static final String ID_ANT_LINE_BREAKPOINT_MARKER "org.eclipse.ant.ui.antLineBreakpointMarker"
org.eclipse.ant.internal.ui.debug.model.DebugMessageIds
public static final String ADD_BREAKPOINT "add"
public static final String BREAKPOINT "breakpoint"
public static final String BUILD_STARTED "build_started"
public static final String CLIENT_REQUEST "client"
public static final String MESSAGE_DELIMITER ","
public static final String PROPERTIES "prop"
public static final int PROPERTY_RUNTIME 2
public static final int PROPERTY_SYSTEM 1
public static final int PROPERTY_USER 0
public static final String PROPERTY_VALUE "value"
public static final String REMOVE_BREAKPOINT "remove"
public static final String RESUME "resume"
public static final String STACK "stack"
public static final String STEP "step"
public static final String STEP_INTO "step_into"
public static final String STEP_OVER "step_over"
public static final String SUSPEND "suspend"
public static final String SUSPENDED "suspended"
public static final String TARGET_FINISHED "target_finished"
public static final String TARGET_STARTED "target_started"
public static final String TASK_FINISHED "task_finished"
public static final String TASK_STARTED "task_started"
public static final String TERMINATE "terminate"
public static final String TERMINATED "terminated"
org.eclipse.ant.internal.ui.dtd.IAtom
public static final int ATTRIBUTE 1
public static final int ELEMENT 0
org.eclipse.ant.internal.ui.dtd.IAttribute
public static final String CDATA "CDATA"
public static final String ENTITIES "ENTITIES"
public static final String ENTITY "ENTITY"
public static final String ENUMERATION "enumeration"
public static final String ID "ID"
public static final String IDREF "IDREF"
public static final String IDREFS "IDREFS"
public static final String NMTOKEN "NMTOKEN"
public static final String NMTOKENS "NMTOKENS"
public static final String NOTATION "NOTATION"
org.eclipse.ant.internal.ui.dtd.IModel
public static final int CHOICE 2
public static final int LEAF 4
public static final int SEQUENCE 1
public static final int UNBOUNDED 2147483647
public static final int UNKNOWN 0
org.eclipse.ant.internal.ui.editor.AntCompletionProposal
public static final int PROPERTY_PROPOSAL 2
public static final int TAG_CLOSING_PROPOSAL 0
public static final int TASK_PROPOSAL 1
org.eclipse.ant.internal.ui.editor.AntEditorCompletionProcessor
protected static final int PROPOSAL_MODE_ATTRIBUTE_PROPOSAL 4
protected static final int PROPOSAL_MODE_ATTRIBUTE_VALUE_PROPOSAL 6
protected static final int PROPOSAL_MODE_BUILDFILE 1
protected static final int PROPOSAL_MODE_NESTED_ELEMENT_PROPOSAL 7
protected static final int PROPOSAL_MODE_NONE 0
protected static final int PROPOSAL_MODE_PROPERTY_PROPOSAL 3
protected static final int PROPOSAL_MODE_TASK_PROPOSAL 2
protected static final int PROPOSAL_MODE_TASK_PROPOSAL_CLOSING 5
org.eclipse.ant.internal.ui.editor.TaskDescriptionProvider
public static final String TASKS_DESCRIPTION_XML_FILE_NAME "/org/eclipse/ant/internal/ui/editor/anttasks_1.6.0.xml"
public static final String XML_ATTRIBUTE_NAME "name"
public static final String XML_ATTRIBUTE_REQUIRED "required"
public static final String XML_TAG_ATTRIBUTE "attribute"
public static final String XML_TAG_ATTRIBUTES "attributes"
public static final String XML_TAG_DESCRIPTION "description"
public static final String XML_TAG_ELEMENT "element"
public static final String XML_TAG_ELEMENTS "elements"
public static final String XML_TAG_STRUCTURE "structure"
public static final String XML_TAG_TASK "task"
public static final String XML_TAG_TASKS "tasks"
org.eclipse.ant.internal.ui.editor.outline.AntEditorMarkerUpdater
public static final String BUILDFILE_PROBLEM_MARKER "org.eclipse.ant.ui.buildFileProblem"
org.eclipse.ant.internal.ui.editor.templates.BuildFileContextType
public static final String BUILDFILE_CONTEXT_TYPE "org.eclipse.ant.ui.templateContextType.buildFile"
org.eclipse.ant.internal.ui.editor.templates.TaskContextType
public static final String TASK_CONTEXT_TYPE "org.eclipse.ant.ui.templateContextType.task"
org.eclipse.ant.internal.ui.editor.text.AntDocumentSetupParticipant
public static final String ANT_PARTITIONING "org.eclipse.ant.ui.antPartitioning"
org.eclipse.ant.internal.ui.editor.text.AntEditorPartitionScanner
public static final String XML_CDATA "__xml_cdata"
public static final String XML_COMMENT "__xml_comment"
public static final String XML_DTD "__xml_dtd"
public static final String XML_TAG "__xml_tag"
org.eclipse.ant.internal.ui.editor.text.IAntEditorColorConstants
public static final String PROCESSING_INSTRUCTIONS_COLOR "org.eclipse.ant.ui.processingInstructionsColor"
public static final String STRING_COLOR "org.eclipse.ant.ui.constantStringsColor"
public static final String TAG_COLOR "org.eclipse.ant.ui.tagsColor"
public static final String TEXT_COLOR "org.eclipse.ant.ui.textColor"
public static final String XML_COMMENT_COLOR "org.eclipse.ant.ui.commentsColor"
public static final String XML_DTD_COLOR "org.eclipse.ant.ui.dtdColor"
org.eclipse.ant.internal.ui.editor.text.XMLProblemAnnotation
public static final String ERROR_ANNOTATION_TYPE "org.eclipse.ui.workbench.texteditor.error"
public static final String INFO_ANNOTATION_TYPE "org.eclipse.ui.workbench.texteditor.info"
public static final String WARNING_ANNOTATION_TYPE "org.eclipse.ui.workbench.texteditor.warning"
org.eclipse.ant.internal.ui.editor.text.XMLReconcilingStrategy
public static final int DELAY 500
org.eclipse.ant.internal.ui.launchConfigurations.AntHomeClasspathEntry
public static final String TYPE_ID "org.eclipse.ant.ui.classpathentry.antHome"
org.eclipse.ant.internal.ui.launchConfigurations.AntStreamsProxy
public static final String ANT_DEBUG_STREAM "org.eclipse.ant.ui.ANT_DEBUG_STREAM"
public static final String ANT_VERBOSE_STREAM "org.eclipse.ant.ui.ANT_VERBOSE_STREAM"
public static final String ANT_WARNING_STREAM "org.eclipse.ant.ui.ANT_WARNING_STREAM"
org.eclipse.ant.internal.ui.launchConfigurations.AntTargetsTab
public static final int SORT_DESCRIPTION 2
public static final int SORT_DESCRIPTION_REVERSE -2
public static final int SORT_NAME 1
public static final int SORT_NAME_REVERSE -1
public static final int SORT_NONE 0
org.eclipse.ant.internal.ui.launchConfigurations.ContributedClasspathEntriesEntry
public static final String TYPE_ID "org.eclipse.ant.ui.classpathentry.extraClasspathEntries"
org.eclipse.ant.internal.ui.launchConfigurations.IAntLaunchConfigurationConstants
public static final String ATTR_ANT_AFTER_CLEAN_TARGETS "org.eclipse.ant.ui.ATTR_ANT_AFTER_CLEAN_TARGETS"
public static final String ATTR_ANT_AUTO_TARGETS "org.eclipse.ant.ui.ATTR_ANT_AUTO_TARGETS"
public static final String ATTR_ANT_CLEAN_TARGETS "org.eclipse.ant.ui.ATTR_ANT_CLEAN_TARGETS"
public static final String ATTR_ANT_CUSTOM_CLASSPATH "org.eclipse.ui.externaltools.ATTR_ANT_CUSTOM_CLASSPATH"
public static final String ATTR_ANT_HOME "org.eclipse.ui.externaltools.ATTR_ANT_HOME"
public static final String ATTR_ANT_MANUAL_TARGETS "org.eclipse.ant.ui.ATTR_ANT_MANUAL_TARGETS"
public static final String ATTR_ANT_PROPERTIES "org.eclipse.ui.externaltools.ATTR_ANT_PROPERTIES"
public static final String ATTR_ANT_PROPERTY_FILES "org.eclipse.ui.externaltools.ATTR_ANT_PROPERTY_FILES"
public static final String ATTR_ANT_TARGETS "org.eclipse.ui.externaltools.ATTR_ANT_TARGETS"
public static final String ATTR_HIDE_INTERNAL_TARGETS "org.eclipse.ui.externaltools.ATTR_HIDE_INTERNAL_TARGETS"
public static final String ATTR_SORT_TARGETS "org.eclipse.ui.externaltoolsATTR_SORT_TARGETS"
public static final String ATTR_TARGETS_UPDATED "org.eclipse.ant.ui.ATTR_TARGETS_UPDATED"
public static final String ID_ANT_BUILDER_LAUNCH_CONFIGURATION_TYPE "org.eclipse.ant.AntBuilderLaunchConfigurationType"
public static final String ID_ANT_LAUNCH_CONFIGURATION_TYPE "org.eclipse.ant.AntLaunchConfigurationType"
public static final String ID_ANT_PROCESS_TYPE "org.eclipse.ant.ui.antProcess"
org.eclipse.ant.internal.ui.launchConfigurations.MessageIds
public static final String BUILD_CANCELLED "cancelled"
public static final String PROCESS_ID "processID"
public static final String TARGET "7"
public static final String TASK "6"
org.eclipse.ant.internal.ui.model.AntModelProblem
public static final int NO_PROBLEM -1
public static final int SEVERITY_ERROR 1
public static final int SEVERITY_FATAL_ERROR 2
public static final int SEVERITY_WARNING 0
org.eclipse.ant.internal.ui.model.IAntModelConstants
public static final String ATTR_ANT_FILE "antfile"
public static final String ATTR_COMMAND "command"
public static final String ATTR_DEFAULT "default"
public static final String ATTR_DESCRIPTION "description"
public static final String ATTR_DESTFILE "destfile"
public static final String ATTR_DIR "dir"
public static final String ATTR_ENVIRONMENT "environment"
public static final String ATTR_EXECUTABLE "executable"
public static final String ATTR_FILE "file"
public static final String ATTR_LOCATION "location"
public static final String ATTR_NAME "name"
public static final String ATTR_RESOURCE "resource"
public static final String ATTR_SRC "src"
public static final String ATTR_TARGET "target"
public static final String ATTR_VALUE "value"
public static final String ATTR_ZIPFILE "zipfile"
org.eclipse.ant.internal.ui.preferences.AntEditorPreferenceConstants
public static final String BUILDFILE_ERROR "error"
public static final String BUILDFILE_IGNORE "ignore"
public static final String BUILDFILE_WARNING "warning"
public static final String CODEASSIST_AUTOACTIVATION "content_assist_autoactivation"
public static final String CODEASSIST_AUTOACTIVATION_DELAY "content_assist_autoactivation_delay"
public static final String CODEASSIST_AUTOACTIVATION_TRIGGERS "content_assist_autoactivation_triggers_java"
public static final String CODEASSIST_AUTOINSERT "content_assist_autoinsert"
public static final String CODEASSIST_PROPOSALS_BACKGROUND "org.eclipse.ant.ui.codeAssistProposalsBackgroundColor"
public static final String CODEASSIST_PROPOSALS_FOREGROUND "org.eclipse.ant.ui.codeAssistProposalsForegroundColor"
public static final String CODEASSIST_USER_DEFINED_TASKS "content_assist_userDefinedTasks"
public static final String EDITOR_BOLD_SUFFIX "_bold"
public static final String EDITOR_FOLDING_COMMENTS "editor_folding_comments"
public static final String EDITOR_FOLDING_DEFINING "editor_folding_defining"
public static final String EDITOR_FOLDING_DTD "editor_folding_dtd"
public static final String EDITOR_FOLDING_ENABLED "editor_folding_enabled"
public static final String EDITOR_FOLDING_TARGETS "editor_folding_targets"
public static final String EDITOR_ITALIC_SUFFIX "_italic"
public static final String EDITOR_MARK_OCCURRENCES "editor_mark_occurrences"
public static final String EDITOR_RECONCILE "editor_reconcile"
public static final String EDITOR_SHOW_SEGMENTS "editor_show_segments"
public static final String EDITOR_SHOW_TEXT_HOVER_AFFORDANCE "editor_show_text_hover_affordance"
public static final String EDITOR_SPACES_FOR_TABS "spaces_for_tabs"
public static final String EDITOR_STICKY_OCCURRENCES "stickyOccurrences"
public static final String FORMATTER_ALIGN "formatter_align"
public static final String FORMATTER_MAX_LINE_LENGTH "formatter_max_line_length"
public static final String FORMATTER_TAB_CHAR "formatter_tab_char"
public static final String FORMATTER_TAB_SIZE "formatter_tab_size"
public static final String FORMATTER_WRAP_LONG "formatter_wrap_long"
public static final String PROBLEM "problem"
public static final String PROBLEM_CLASSPATH "problem_classpath"
public static final String PROBLEM_IMPORTS "problem_imports"
public static final String PROBLEM_PROPERTIES "problem_properties"
public static final String PROBLEM_SECURITY "problem_security"
public static final String PROBLEM_TASKS "problem_tasks"
public static final String TEMPLATES_USE_CODEFORMATTER "templates_use_codeformatter"
org.eclipse.ant.internal.ui.preferences.AntPage
protected static final int ADD_BUTTON 1025
protected static final int EDIT_BUTTON 1026
protected static final int REMOVE_BUTTON 1027
org.eclipse.ant.internal.ui.preferences.ClasspathModel
public static final int ANT_HOME 0
public static final int CONTRIBUTED 3
public static final int GLOBAL_USER 1
public static final int USER 2
org.eclipse.ant.internal.ui.preferences.DialogSettingsHelper
public static final String DIALOG_HEIGHT "org.eclipse.ant.ui.ATTR_ANT_DIALOG_HEIGHT"
public static final String DIALOG_ORIGIN_X "org.eclipse.ant.ui.ATTR_ANT_DIALOG_X_ORIGIN"
public static final String DIALOG_ORIGIN_Y "org.eclipse.ant.ui.ATTR_ANT_DIALOG_Y_ORIGIN"
public static final String DIALOG_WIDTH "org.eclipse.ant.ui.ATTR_ANT_DIALOG_WIDTH"
org.eclipse.ant.internal.ui.views.actions.AntOpenWithMenu
public static final String ID "org.eclipse.ant.ui.AntOpenWithMenu"
org.eclipse.compare.CompareConfiguration
public static final String IGNORE_WHITESPACE "IGNORE_WHITESPACE"
public static final String SHOW_PSEUDO_CONFLICTS "SHOW_PSEUDO_CONFLICTS"
public static final String USE_OUTLINE_VIEW "USE_OUTLINE_VIEW"
org.eclipse.compare.CompareEditorInput
public static final String DIRTY_STATE "DIRTY_STATE"
org.eclipse.compare.CompareUI
public static final String COMPARE_VIEWER_TITLE "org.eclipse.compare.CompareUI.CompareViewerTitle"
public static final String PLUGIN_ID "org.eclipse.compare"
public static final String PREFERENCE_PAGE_ID "org.eclipse.compare.internal.ComparePreferencePage"
org.eclipse.compare.IStreamMerger
public static final int CONFLICT 1
public static final int INTERNAL_ERROR 2
public static final int OK 0
org.eclipse.compare.ITypedElement
public static final String FOLDER_TYPE "FOLDER"
public static final String TEXT_TYPE "txt"
public static final String UNKNOWN_TYPE "???"
org.eclipse.compare.contentmergeviewer.IDocumentRange
public static final String RANGE_CATEGORY "DocumentRangeCategory"
org.eclipse.compare.internal.CompareEditor
public static final String CONFIRM_SAVE_PROPERTY "org.eclipse.compare.internal.CONFIRM_SAVE_PROPERTY"
public static final String IGNORE_WHITESPACE "org.eclipse.compare.IgnoreWhitespace"
public static final String INITIALLY_SHOW_ANCESTOR_PANE "org.eclipse.compare.InitiallyShowAncestorPane"
public static final String OPEN_STRUCTURE_COMPARE "org.eclipse.compare.OpenStructureCompare"
public static final String PATH_FILTER "org.eclipse.compare.PathFilter"
public static final String PREF_SAVE_ALL_EDITORS "org.eclipse.compare.SaveAllEditors"
public static final String SHOW_MORE_INFO "org.eclipse.compare.ShowMoreInfo"
public static final String SHOW_PSEUDO_CONFLICTS "org.eclipse.compare.ShowPseudoConflicts"
public static final String SYNCHRONIZE_SCROLLING "org.eclipse.compare.SynchronizeScrolling"
public static final String USE_SINGLE_LINE "org.eclipse.compare.UseSingleLine"
org.eclipse.compare.internal.CompareUIPlugin
public static final String CTOOL_NEXT "elcl16/next_nav.gif"
public static final String CTOOL_PREV "elcl16/prev_nav.gif"
public static final String DTOOL_NEXT "dlcl16/next_nav.gif"
public static final String DTOOL_PREV "dlcl16/prev_nav.gif"
public static final String ETOOL_NEXT "elcl16/next_nav.gif"
public static final String ETOOL_PREV "elcl16/prev_nav.gif"
org.eclipse.compare.internal.ICompareContextIds
public static final String ADD_FROM_HISTORY_DIALOG "org.eclipse.compare.add_from_history_dialog_context"
public static final String BINARY_COMPARE_VIEW "org.eclipse.compare.binary_compare_view_context"
public static final String COMPARE_DIALOG "org.eclipse.compare.compare_dialog_context"
public static final String COMPARE_EDITOR "org.eclipse.compare.compare_editor_context"
public static final String COMPARE_PREFERENCE_PAGE "org.eclipse.compare.compare_preference_page_context"
public static final String COMPARE_WITH_EDITION_DIALOG "org.eclipse.compare.compare_with_edition_dialog_context"
public static final String DIFF_VIEW "org.eclipse.compare.diff_view_context"
public static final String EDITION_DIALOG "org.eclipse.compare.edition_dialog_context"
public static final String GLOBAL_NEXT_DIFF_ACTION "org.eclipse.compare.global_next_diff_action_context"
public static final String GLOBAL_PREVIOUS_DIFF_ACTION "org.eclipse.compare.global_previous_diff_action_context"
public static final String IGNORE_WHITESPACE_ACTION "org.eclipse.compare.ignore_whitespace_action_context"
public static final String IMAGE_COMPARE_VIEW "org.eclipse.compare.image_compare_view_context"
public static final String NEXT_DIFF_ACTION "org.eclipse.compare.next_diff_action_context"
public static final String PATCH_INPUT_WIZARD_PAGE "org.eclipse.compare.patch_input_wizard_page_context"
public static final String PATCH_PREVIEW_WIZARD_PAGE "org.eclipse.compare.patch_preview_wizard_page_context"
public static final String PREFIX "org.eclipse.compare."
public static final String PREVIOUS_DIFF_ACTION "org.eclipse.compare.previous_diff_action_context"
public static final String REPLACE_WITH_EDITION_DIALOG "org.eclipse.compare.replace_with_edition_dialog_context"
public static final String TEXT_MERGE_VIEW "org.eclipse.compare.text_merge_view_context"
org.eclipse.compare.internal.INavigatable
public static final String NAVIGATOR_PROPERTY "org.eclipse.compare.internal.Navigator"
org.eclipse.compare.internal.IOpenable
public static final String OPENABLE_PROPERTY "org.eclipse.compare.internal.Openable"
org.eclipse.compare.internal.MergeSourceViewer
public static final String COPY_ID "copy"
public static final String CUT_ID "cut"
public static final String DELETE_ID "delete"
public static final String PASTE_ID "paste"
public static final String REDO_ID "redo"
public static final String SAVE_ID "save"
public static final String SELECT_ALL_ID "selectAll"
public static final String UNDO_ID "undo"
org.eclipse.compare.rangedifferencer.RangeDifference
public static final int ANCESTOR 4
public static final int CHANGE 2
public static final int ERROR 5
public static final int LEFT 3
public static final int NOCHANGE 0
public static final int RIGHT 2
org.eclipse.compare.structuremergeviewer.Differencer
public static final int ADDITION 1
public static final int CHANGE 3
public static final int CHANGE_TYPE_MASK 3
public static final int CONFLICTING 12
public static final int DELETION 2
public static final int DIRECTION_MASK 12
public static final int LEFT 4
public static final int NO_CHANGE 0
public static final int PSEUDO_CONFLICT 16
public static final int RIGHT 8
org.eclipse.core.boot.BootLoader
public static final String ARCH_PA_RISC "PA_RISC"
public static final String ARCH_PPC "ppc"
public static final String ARCH_SPARC "sparc"
public static final String ARCH_X86 "x86"
public static final String OS_AIX "aix"
public static final String OS_HPUX "hpux"
public static final String OS_LINUX "linux"
public static final String OS_MACOSX "macosx"
public static final String OS_QNX "qnx"
public static final String OS_SOLARIS "solaris"
public static final String OS_UNKNOWN "unknown"
public static final String OS_WIN32 "win32"
public static final String PI_BOOT "org.eclipse.core.boot"
public static final String WS_CARBON "carbon"
public static final String WS_GTK "gtk"
public static final String WS_MOTIF "motif"
public static final String WS_PHOTON "photon"
public static final String WS_UNKNOWN "unknown"
public static final String WS_WIN32 "win32"
org.eclipse.core.boot.IPlatformConfiguration.ISitePolicy
public static final int USER_EXCLUDE 1
public static final int USER_INCLUDE 0
org.eclipse.core.commands.IHandlerAttributes
public static final String ATTRIBUTE_HANDLED "handled"
org.eclipse.core.commands.ParameterizedCommand
public static final int INDEX_PARAMETER_ID 0
public static final int INDEX_PARAMETER_NAME 1
public static final int INDEX_PARAMETER_VALUE_NAME 2
public static final int INDEX_PARAMETER_VALUE_VALUE 3
org.eclipse.core.commands.common.AbstractNamedHandleEvent
protected static final int CHANGED_DEFINED 1
protected static final int CHANGED_DESCRIPTION 2
protected static final int CHANGED_NAME 4
protected static final int LAST_USED_BIT 4
org.eclipse.core.commands.operations.IOperationHistory
public static final int EXECUTE 1
public static final int REDO 3
public static final int UNDO 2
org.eclipse.core.commands.operations.OperationHistoryEvent
public static final int ABOUT_TO_EXECUTE 1
public static final int ABOUT_TO_REDO 2
public static final int ABOUT_TO_UNDO 3
public static final int DONE 4
public static final int OPERATION_ADDED 5
public static final int OPERATION_CHANGED 6
public static final int OPERATION_NOT_OK 7
public static final int OPERATION_REMOVED 8
public static final int REDONE 9
public static final int UNDONE 10
org.eclipse.core.commands.operations.OperationStatus
public static final int NOTHING_TO_REDO 1
public static final int NOTHING_TO_UNDO 2
public static final int OPERATION_INVALID 3
org.eclipse.core.expressions.Expression
protected static final String ATT_VALUE "value"
org.eclipse.core.expressions.ExpressionTagNames
public static final String ADAPT "adapt"
public static final String AND "and"
public static final String COUNT "count"
public static final String ENABLEMENT "enablement"
public static final String EQUALS "equals"
public static final String INSTANCEOF "instanceof"
public static final String ITERATE "iterate"
public static final String NOT "not"
public static final String OR "or"
public static final String RESOLVE "resolve"
public static final String SYSTEM_TEST "systemTest"
public static final String TEST "test"
public static final String WITH "with"
org.eclipse.core.filebuffers.IFileBufferStatusCodes
public static final int CONTENT_CHANGE_FAILED 1
public static final int CREATION_FAILED 2
org.eclipse.core.internal.boot.PlatformURLBaseConnection
public static final String PLATFORM "base"
public static final String PLATFORM_URL_STRING "platform:/base/"
org.eclipse.core.internal.boot.PlatformURLHandler
public static final String BUNDLE "bundle"
public static final String FILE "file"
public static final String JAR "jar"
public static final String JAR_SEPARATOR "!/"
public static final String PROTOCOL "platform"
public static final String PROTOCOL_SEPARATOR ":"
org.eclipse.core.internal.commands.util.Util
public static final String ZERO_LENGTH_STRING ""
org.eclipse.core.internal.content.ContentType
public static final String PREF_DEFAULT_CHARSET "charset"
public static final String PREF_FILE_EXTENSIONS "file-extensions"
public static final String PREF_FILE_NAMES "file-names"
org.eclipse.core.internal.content.ContentTypeBuilder
public static final String PT_CONTENTTYPES "contentTypes"
org.eclipse.core.internal.content.ContentTypeManager
public static final int BLOCK_SIZE 1024
public static final String CONTENT_TYPE_PREF_NODE "org.eclipse.core.runtime/content-types"
org.eclipse.core.internal.content.ContentTypeVisitor
public static final int CONTINUE 0
public static final int RETURN 1
public static final int STOP 2
org.eclipse.core.internal.dtree.AbstractDataTreeNode
public static final int T_COMPLETE_NODE 0
public static final int T_DELETED_NODE 2
public static final int T_DELTA_NODE 1
public static final int T_NO_DATA_DELTA_NODE 3
org.eclipse.core.internal.dtree.DataTreeWriter
public static final int D_INFINITE -1
org.eclipse.core.internal.dtree.NodeComparison
public static final int K_ADDED 1
public static final int K_CHANGED 4
public static final int K_REMOVED 2
org.eclipse.core.internal.events.LifecycleEvent
public static final int PRE_LINK_COPY 256
public static final int PRE_LINK_CREATE 512
public static final int PRE_LINK_DELETE 1024
public static final int PRE_LINK_MOVE 2048
public static final int PRE_PROJECT_CHANGE 2
public static final int PRE_PROJECT_CLOSE 1
public static final int PRE_PROJECT_COPY 4
public static final int PRE_PROJECT_CREATE 8
public static final int PRE_PROJECT_DELETE 16
public static final int PRE_PROJECT_MOVE 64
public static final int PRE_PROJECT_OPEN 32
org.eclipse.core.internal.events.ResourceStats
public static final String EVENT_BUILDERS "org.eclipse.core.resources/perf/builders"
public static final String EVENT_LISTENERS "org.eclipse.core.resources/perf/listeners"
public static final String EVENT_SAVE_PARTICIPANTS "org.eclipse.core.resources/perf/save.participants"
public static final String EVENT_SNAPSHOT "org.eclipse.core.resources/perf/snapshot"
org.eclipse.core.internal.expressions.ExpressionStatus
public static final int MISSING_ATTRIBUTE 50
public static final int NO_NAMESPACE_PROVIDED 300
public static final int STRING_NOT_CORRECT_ESCAPED 302
public static final int STRING_NOT_TERMINATED 303
public static final int TEST_EXPRESSION_NOT_A_BOOLEAN 203
public static final int TYPE_EXTENDER_INCORRECT_TYPE 202
public static final int TYPE_EXTENDER_PLUGIN_NOT_LOADED 200
public static final int TYPE_EXTENDER_UNKOWN_METHOD 201
public static final int VALUE_IS_NOT_AN_INTEGER 5
public static final int VARAIBLE_POOL_ARGUMENT_IS_NOT_A_STRING 101
public static final int VARAIBLE_POOL_WRONG_NUMBER_OF_ARGUMENTS 100
public static final int VARIABLE_IS_NOT_A_COLLECTION 3
public static final int VARIABLE_IS_NOT_A_LIST 4
public static final int VARIABLE_NOT_DEFINED 301
public static final int WRONG_ATTRIBUTE_VALUE 51
org.eclipse.core.internal.filebuffers.FileBuffersPlugin
public static final String PLUGIN_ID "org.eclipse.core.filebuffers"
org.eclipse.core.internal.indexing.FieldDef
public static final int F_BYTE 1
public static final int F_BYTES 5
public static final int F_INT 2
public static final int F_LONG 4
public static final int F_UINT 3
org.eclipse.core.internal.indexing.IndexedStoreException
public static final int ContextNotAvailable 30
public static final int EntryKeyLengthError 1
public static final int EntryNotRemoved 2
public static final int EntryRemoved 33
public static final int EntryValueLengthError 3
public static final int EntryValueNotUpdated 4
public static final int GenericError 0
public static final int IndexExists 9
public static final int IndexNodeNotCreated 8
public static final int IndexNodeNotRetrieved 5
public static final int IndexNodeNotSplit 7
public static final int IndexNodeNotStored 6
public static final int IndexNotCreated 10
public static final int IndexNotFound 11
public static final int IndexNotRemoved 12
public static final int MetadataRequestError 32
public static final int ObjectExists 13
public static final int ObjectIDInvalid 31
public static final int ObjectNotAcquired 14
public static final int ObjectNotCreated 15
public static final int ObjectNotFound 16
public static final int ObjectNotReleased 17
public static final int ObjectNotRemoved 18
public static final int ObjectNotStored 20
public static final int ObjectNotUpdated 19
public static final int ObjectTypeError 21
public static final int StoreEmpty 22
public static final int StoreFormatError 23
public static final int StoreIsOpen 35
public static final int StoreNotClosed 26
public static final int StoreNotCommitted 36
public static final int StoreNotConverted 34
public static final int StoreNotCreated 24
public static final int StoreNotFlushed 27
public static final int StoreNotOpen 25
public static final int StoreNotOpened 28
public static final int StoreNotReadWrite 29
public static final int StoreNotRolledBack 37
org.eclipse.core.internal.indexing.ObjectAddress
public static final int Size 4
org.eclipse.core.internal.indexing.ObjectStore
protected static final int CurrentObjectStoreVersion 1
public static final int MAXIMUM_OBJECT_SIZE 7612
protected static final int ObjectStoreMetadataAreaID 1
org.eclipse.core.internal.indexing.ObjectStoreException
public static final int GenericFailure 0
public static final int InternalFailure 1
public static final int MetadataRequestFailure 40
public static final int ObjectExistenceFailure 25
public static final int ObjectHeaderFailure 26
public static final int ObjectInsertFailure 27
public static final int ObjectIsLocked 30
public static final int ObjectRemoveFailure 28
public static final int ObjectSizeFailure 24
public static final int ObjectTypeFailure 23
public static final int ObjectUpdateFailure 29
public static final int PageReadFailure 20
public static final int PageVacancyFailure 22
public static final int PageWriteFailure 21
public static final int StoreCloseFailure 13
public static final int StoreConversionFailure 11
public static final int StoreCreateFailure 10
public static final int StoreOpenFailure 12
org.eclipse.core.internal.indexing.Page
public static final int SIZE 8192
org.eclipse.core.internal.indexing.PageStoreException
public static final int CommitFailure 6
public static final int ConversionFailure 9
public static final int CreateFailure 1
public static final int IntegrityFailure 7
public static final int LengthFailure 3
public static final int LogCreateFailure 20
public static final int LogOpenFailure 21
public static final int LogReadFailure 23
public static final int LogWriteFailure 24
public static final int MetadataRequestFailure 8
public static final int OpenFailure 2
public static final int ReadFailure 5
public static final int WriteFailure 4
org.eclipse.core.internal.indexing.StoredObject
public static final int TYPE_LENGTH 2
public static final int TYPE_OFFSET 0
org.eclipse.core.internal.localstore.Bucket.Visitor
public static final int RETURN 2
org.eclipse.core.internal.localstore.BucketTree
public static final int DEPTH_INFINITE 2147483647
public static final int DEPTH_ONE 1
public static final int DEPTH_ZERO 0
org.eclipse.core.internal.localstore.HistoryBucket
public static final byte VERSION 2
org.eclipse.core.internal.localstore.HistoryBucket.HistoryEntry
public static final int DATA_LENGTH 24
org.eclipse.core.internal.localstore.ILocalStoreConstants
public static final int SIZE_COUNTER 1
public static final int SIZE_KEY_SUFFIX 9
public static final int SIZE_LASTMODIFIED 8
org.eclipse.core.internal.localstore.RefreshLocalVisitor
protected static final int RL_IN_SYNC 1
protected static final int RL_NOT_IN_SYNC 2
protected static final int RL_UNKNOWN 0
public static final int TOTAL_WORK 250
org.eclipse.core.internal.localstore.SafeChunkyInputStream
protected static final int BUFFER_SIZE 8192
org.eclipse.core.internal.localstore.SafeFileInputStream
protected static final String EXTENSION ".bak"
org.eclipse.core.internal.localstore.SafeFileOutputStream
org.eclipse.core.internal.model.IModel
public static final String ELEMENT "element"
public static final String ELEMENT_NAME "name"
public static final String ELEMENT_VALUE "value"
public static final String EXTENSION "extension"
public static final String EXTENSION_ID "id"
public static final String EXTENSION_NAME "name"
public static final String EXTENSION_POINT "extension-point"
public static final String EXTENSION_POINT_ID "id"
public static final String EXTENSION_POINT_NAME "name"
public static final String EXTENSION_POINT_SCHEMA "schema"
public static final String EXTENSION_TARGET "point"
public static final String FALSE "false"
public static final String FRAGMENT "fragment"
public static final String FRAGMENT_ID "id"
public static final String FRAGMENT_NAME "name"
public static final String FRAGMENT_PLUGIN_ID "plugin-id"
public static final String FRAGMENT_PLUGIN_MATCH "match"
public static final String FRAGMENT_PLUGIN_MATCH_COMPATIBLE "compatible"
public static final String FRAGMENT_PLUGIN_MATCH_EQUIVALENT "equivalent"
public static final String FRAGMENT_PLUGIN_MATCH_GREATER_OR_EQUAL "greaterOrEqual"
public static final String FRAGMENT_PLUGIN_MATCH_PERFECT "perfect"
public static final String FRAGMENT_PLUGIN_VERSION "plugin-version"
public static final String FRAGMENT_PROVIDER "provider-name"
public static final String FRAGMENT_VERSION "version"
public static final int INDENT 2
public static final String LIBRARY_EXPORT "export"
public static final String LIBRARY_EXPORT_MASK "name"
public static final String LIBRARY_NAME "name"
public static final String LIBRARY_PACKAGES "packages"
public static final String LIBRARY_PACKAGES_PREFIXES "prefixes"
public static final String LIBRARY_SOURCE "source"
public static final String LIBRARY_TYPE "type"
public static final String PLUGIN "plugin"
public static final String PLUGIN_CLASS "class"
public static final String PLUGIN_ID "id"
public static final String PLUGIN_KEY_VERSION_SEPARATOR "_"
public static final String PLUGIN_NAME "name"
public static final String PLUGIN_PROVIDER "provider-name"
public static final String PLUGIN_REQUIRES "requires"
public static final String PLUGIN_REQUIRES_EXPORT "export"
public static final String PLUGIN_REQUIRES_IMPORT "import"
public static final String PLUGIN_REQUIRES_MATCH "match"
public static final String PLUGIN_REQUIRES_MATCH_COMPATIBLE "compatible"
public static final String PLUGIN_REQUIRES_MATCH_EQUIVALENT "equivalent"
public static final String PLUGIN_REQUIRES_MATCH_EXACT "exact"
public static final String PLUGIN_REQUIRES_MATCH_GREATER_OR_EQUAL "greaterOrEqual"
public static final String PLUGIN_REQUIRES_MATCH_PERFECT "perfect"
public static final String PLUGIN_REQUIRES_OPTIONAL "optional"
public static final String PLUGIN_REQUIRES_PLATFORM "platform-version"
public static final String PLUGIN_REQUIRES_PLUGIN "plugin"
public static final String PLUGIN_REQUIRES_PLUGIN_VERSION "version"
public static final String PLUGIN_VENDOR "vendor-name"
public static final String PLUGIN_VERSION "version"
public static final String PROPERTY "property"
public static final String PROPERTY_NAME "name"
public static final int RADIX 36
public static final String REGISTRY "plugin-registry"
public static final String REGISTRY_PATH "path"
public static final String RUNTIME "runtime"
public static final String TRUE "true"
org.eclipse.core.internal.preferences.DefaultPreferences
public static final String PRODUCT_KEY "preferenceCustomization"
org.eclipse.core.internal.preferences.EclipsePreferences
public static final String DEFAULT_PREFERENCES_DIRNAME ".settings"
protected static final String DOUBLE_SLASH "//"
protected static final String EMPTY_STRING ""
public static final String PREFS_FILE_EXTENSION "prefs"
protected static final String VERSION_KEY "eclipse.preferences.version"
protected static final String VERSION_VALUE "1"
org.eclipse.core.internal.properties.PropertyBucket
public static final byte INDEX 1
public static final byte QNAME 2
org.eclipse.core.internal.properties.PropertyStore
public static final int CREATE 0
public static final int FAIL_MISSING 1
public static final int IGNORE_MISSING 0
public static final int SET_SKIP 3
public static final int SET_UPDATE 2
public static final int UPDATE 1
org.eclipse.core.internal.refresh.RefreshManager
public static final String DEBUG_PREFIX "Auto-refresh: "
org.eclipse.core.internal.registry.ExtensionsParser
public static final String BUNDLE_UID "id"
public static final int PARSE_PROBLEM 1
org.eclipse.core.internal.registry.HashtableOfStringAndInt
public static final int MISSING_ELEMENT -2147483648
org.eclipse.core.internal.registry.KeyedHashSet
protected static final int MINIMUM_SIZE 7
org.eclipse.core.internal.registry.ReferenceHashSet
public static final int HARD 0
public static final int SOFT 1
public static final int WEAK 2
org.eclipse.core.internal.registry.ReferenceMap
org.eclipse.core.internal.resources.CharsetDeltaJob
public static final String FAMILY_CHARSET_DELTA "org.eclipse.core.resourcescharsetJobFamily"
org.eclipse.core.internal.resources.CharsetManager
public static final String ENCODING_PREF_NODE "encoding"
org.eclipse.core.internal.resources.ContentDescriptionManager
public static final byte EMPTY_CACHE 1
public static final String FAMILY_DESCRIPTION_CACHE_FLUSH "org.eclipse.core.resources.contentDescriptionCacheFamily"
public static final byte FLUSHING_CACHE 4
public static final byte INVALID_CACHE 3
public static final byte USED_CACHE 2
org.eclipse.core.internal.resources.ICoreConstants
public static final int CRASH_DETECTED 10035
public static final long I_NULL_SYNC_INFO -1l
public static final int M_CHILDREN_UNKNOWN 1048576
public static final int M_CONTENT_CACHE 393216
public static final int M_DEFAULT_CONTENT_DESCRIPTION 262144
public static final int M_DERIVED 16384
public static final int M_LINK 65536
public static final int M_LOCAL_EXISTS 2
public static final int M_MARKERS_SNAP_DIRTY 4096
public static final int M_NO_CONTENT_DESCRIPTION 131072
public static final int M_OPEN 1
public static final int M_PHANTOM 8
public static final int M_SYNCINFO_SNAP_DIRTY 8192
public static final int M_TEAM_PRIVATE_MEMBER 32768
public static final int M_TYPE 3840
public static final int M_TYPE_START 8
public static final int M_USED 16
public static final int MINIMUM_FILE_SEGMENT_LENGTH 2
public static final int MINIMUM_FOLDER_SEGMENT_LENGTH 2
public static final int NULL_FLAG -1
public static final int OPERATION_FAILED 10002
public static final String PREF_VERSION "1"
public static final String PREF_VERSION_KEY "version"
public static final int PROJECT_SEGMENT_LENGTH 1
public static final int WORKSPACE_TREE_VERSION_1 67305985
public static final int WORKSPACE_TREE_VERSION_2 67305986
org.eclipse.core.internal.resources.IModelObjectConstants
public static final String ARGUMENTS "arguments"
public static final String AUTOBUILD "autobuild"
public static final String BUILD_COMMAND "buildCommand"
public static final String BUILD_ORDER "buildOrder"
public static final String BUILD_SPEC "buildSpec"
public static final String BUILD_TRIGGERS "triggers"
public static final String COMMENT "comment"
public static final String DICTIONARY "dictionary"
public static final String FILE_STATE_LONGEVITY "fileStateLongevity"
public static final String KEY "key"
public static final String LINK "link"
public static final String LINKED_RESOURCES "linkedResources"
public static final String LOCATION "location"
public static final String MAX_FILE_STATE_SIZE "maxFileStateSize"
public static final String MAX_FILE_STATES "maxFileStates"
public static final String NATURE "nature"
public static final String NATURES "natures"
public static final String PROJECT "project"
public static final String PROJECT_DESCRIPTION "projectDescription"
public static final String PROJECTS "projects"
public static final String SNAPSHOT_INTERVAL "snapshotInterval"
public static final String TRIGGER_AUTO "auto"
public static final String TRIGGER_CLEAN "clean"
public static final String TRIGGER_FULL "full"
public static final String TRIGGER_INCREMENTAL "incremental"
public static final String TYPE "type"
public static final String WORKSPACE_DESCRIPTION "workspaceDescription"
org.eclipse.core.internal.resources.MarkerAttributeMap
protected static final int DEFAULT_SIZE 16
protected static final int GROW_SIZE 10
org.eclipse.core.internal.resources.MarkerInfo
protected static final long UNDEFINED_ID -1l
org.eclipse.core.internal.resources.MarkerReader_1
public static final int ATTRIBUTE_BOOLEAN 0
public static final int ATTRIBUTE_INTEGER 1
public static final int ATTRIBUTE_NULL -1
public static final int ATTRIBUTE_STRING 2
public static final int INDEX 1
public static final int QNAME 2
org.eclipse.core.internal.resources.MarkerReader_2
public static final byte ATTRIBUTE_BOOLEAN 1
public static final byte ATTRIBUTE_INTEGER 2
public static final byte ATTRIBUTE_NULL 0
public static final byte ATTRIBUTE_STRING 3
org.eclipse.core.internal.resources.MarkerReader_3
org.eclipse.core.internal.resources.MarkerSet
protected static final int MINIMUM_SIZE 5
org.eclipse.core.internal.resources.MarkerSnapshotReader_1
org.eclipse.core.internal.resources.MarkerSnapshotReader_2
org.eclipse.core.internal.resources.MarkerWriter
public static final int MARKERS_SAVE_VERSION 3
public static final int MARKERS_SNAP_VERSION 2
org.eclipse.core.internal.resources.PlatformURLResourceConnection
public static final String RESOURCE "resource"
public static final String RESOURCE_URL_STRING "platform:/resource/"
org.eclipse.core.internal.resources.PreferenceInitializer
public static final boolean PREF_AUTO_BUILDING_DEFAULT true
public static final boolean PREF_AUTO_REFRESH_DEFAULT false
public static final String PREF_BUILD_ORDER_DEFAULT ""
public static final boolean PREF_DEFAULT_BUILD_ORDER_DEFAULT true
public static final String PREF_DELTA_EXPIRATION "delta.expiration"
public static final long PREF_DELTA_EXPIRATION_DEFAULT 2592000000l
public static final boolean PREF_DISABLE_LINKING_DEFAULT false
public static final String PREF_ENCODING_DEFAULT ""
public static final long PREF_FILE_STATE_LONGEVITY_DEFAULT 604800000l
public static final int PREF_MAX_BUILD_ITERATIONS_DEFAULT 10
public static final long PREF_MAX_FILE_STATE_SIZE_DEFAULT 1048576l
public static final int PREF_MAX_FILE_STATES_DEFAULT 50
public static final String PREF_OPERATIONS_PER_SNAPSHOT "snapshots.operations"
public static final int PREF_OPERATIONS_PER_SNAPSHOT_DEFAULT 100
public static final long PREF_SNAPSHOT_INTERVAL_DEFAULT 300000l
org.eclipse.core.internal.resources.ProjectDescriptionReader
protected static final int S_BUILD_COMMAND 0
protected static final int S_BUILD_COMMAND_ARGUMENTS 1
protected static final int S_BUILD_COMMAND_NAME 2
protected static final int S_BUILD_COMMAND_TRIGGERS 3
protected static final int S_BUILD_SPEC 4
protected static final int S_DICTIONARY 5
protected static final int S_DICTIONARY_KEY 6
protected static final int S_DICTIONARY_VALUE 7
protected static final int S_INITIAL 8
protected static final int S_LINK 9
protected static final int S_LINK_LOCATION 10
protected static final int S_LINK_NAME 11
protected static final int S_LINK_TYPE 12
protected static final int S_LINKED_RESOURCES 13
protected static final int S_NATURE_NAME 14
protected static final int S_NATURES 15
protected static final int S_PROJECT_COMMENT 16
protected static final int S_PROJECT_DESC 17
protected static final int S_PROJECT_NAME 18
protected static final int S_PROJECTS 19
protected static final int S_REFERENCED_PROJECT_NAME 20
org.eclipse.core.internal.resources.ResourceInfo
protected static final int LOWER 65535
protected static final int UPPER -65536
org.eclipse.core.internal.resources.SaveManager
protected static final String CLEAR_DELTA_PREFIX "clearDelta_"
protected static final String DELTA_EXPIRATION_PREFIX "deltaExpiration_"
protected static final int DONE_SAVING 3
protected static final int NO_OP_THRESHOLD 20
protected static final int PREPARE_TO_SAVE 1
protected static final int ROLLBACK 4
protected static final String SAVE_NUMBER_PREFIX "saveNumber_"
protected static final int SAVING 2
org.eclipse.core.internal.resources.SyncInfoReader_2
org.eclipse.core.internal.resources.SyncInfoReader_3
org.eclipse.core.internal.resources.SyncInfoWriter
public static final int SYNCINFO_SAVE_VERSION 3
public static final int SYNCINFO_SNAP_VERSION 3
org.eclipse.core.internal.resources.Workspace
protected static final String REFRESH_ON_STARTUP "-refresh"
org.eclipse.core.internal.resources.WorkspacePreferences
public static final String PROJECT_SEPARATOR "/"
org.eclipse.core.internal.resources.XMLWriter
protected static final String XML_VERSION ""
org.eclipse.core.internal.resources.mapping.RemoteResourceMappingContext
public static final int FILE_CONTENTS_REQUIRED 1
public static final int NONE 0
org.eclipse.core.internal.runtime.Cipher
public static final int DECRYPT_MODE -1
public static final int ENCRYPT_MODE 1
org.eclipse.core.internal.runtime.CompatibilityHelper
public static final String PI_RUNTIME_COMPATIBILITY "org.eclipse.core.runtime.compatibility"
org.eclipse.core.internal.runtime.InternalPlatform
public static final String PROP_ADAPTOR "osgi.adaptor"
public static final String PROP_APPLICATION "eclipse.application"
public static final String PROP_ARCH "osgi.arch"
public static final String PROP_CHECK_CONFIG "osgi.checkConfiguration"
public static final String PROP_CONFIG_AREA "osgi.configuration.area"
public static final String PROP_CONSOLE "osgi.console"
public static final String PROP_CONSOLE_CLASS "osgi.consoleClass"
public static final String PROP_CONSOLE_LOG "eclipse.consoleLog"
public static final String PROP_DEBUG "osgi.debug"
public static final String PROP_DEV "osgi.dev"
public static final String PROP_EXITCODE "eclipse.exitcode"
public static final String PROP_INSTALL_AREA "osgi.install.area"
public static final String PROP_INSTANCE_AREA "osgi.instance.area"
public static final String PROP_MANIFEST_CACHE "osgi.manifest.cache"
public static final String PROP_NL "osgi.nl"
public static final String PROP_NO_LAZY_CACHE_LOADING "eclipse.noLazyRegistryCacheLoading"
public static final String PROP_NO_REGISTRY_CACHE "eclipse.noRegistryCache"
public static final String PROP_NO_REGISTRY_FLUSHING "eclipse.noRegistryFlushing"
public static final String PROP_OS "osgi.os"
public static final String PROP_PRODUCT "eclipse.product"
public static final String PROP_SYSPATH "osgi.syspath"
public static final String PROP_USER_AREA "osgi.user.area"
public static final String PROP_WS "osgi.ws"
org.eclipse.core.internal.runtime.ListenerList
public static final int EQUALITY 0
public static final int IDENTITY 1
org.eclipse.core.internal.runtime.ObjectMap
org.eclipse.core.internal.runtime.PlatformURLConfigConnection
public static final String CONFIG "config"
org.eclipse.core.internal.runtime.PlatformURLFragmentConnection
org.eclipse.core.internal.runtime.PlatformURLMetaConnection
public static final String META "meta"
org.eclipse.core.internal.runtime.PlatformURLPluginConnection
org.eclipse.core.internal.utils.KeyedHashSet
org.eclipse.core.internal.utils.ObjectMap
org.eclipse.core.internal.utils.Policy
public static final boolean buildOnCancel false
public static final long MAX_BUILD_DELAY 1000l
public static final long MIN_BUILD_DELAY 100l
public static final int totalWork 100
org.eclipse.core.internal.utils.UniversalUniqueIdentifier
public static final int BYTE_MASK 255
public static final int BYTES_SIZE 16
public static final int CLOCK_SEQUENCE_HIGH_AND_RESERVED 8
public static final int CLOCK_SEQUENCE_LOW 9
public static final int HIGH_NIBBLE_MASK 240
public static final int HOST_ADDRESS_BYTE_SIZE 4
public static final int LOW_NIBBLE_MASK 15
public static final int MAX_CLOCK_ADJUSTMENT 32767
public static final int MAX_CLOCK_SEQUENCE 16384
public static final int MOST_SIGINIFICANT_BIT_MASK 128
public static final int MOST_SIGNIFICANT_THREE_BITS_MASK 224
public static final int MOST_SIGNIFICANT_TWO_BITS_MASK 192
public static final int NODE_ADDRESS_BYTE_SIZE 6
public static final int NODE_ADDRESS_START 10
public static final int NODE_ADDRESS_STOP 13
public static final int PrintStringSize 32
public static final int SHIFT_NIBBLE 4
